has anyone ported to a TPIS bigmouth gasket on stock manifold
Old Dec 6, 2002 | 04:58 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
had any one done this i? i have ordered the gaskets already and just wanted to know how to do the lower intake because i looked at the gasket and it looks like it will go to thin on some parts and i wouldnt want to break through anything ya know.... well please let me know about this one guys.... thanks
clayton
Old Dec 6, 2002 | 09:36 PM
86IROCTHD's Avatar
Car: 88 Trans Am
come on guys
come on guys...... HELP ME lol
Old Dec 7, 2002 | 01:51 AM
age's Avatar
age
Car: 1992 Z28 1LE
I honestly do not think that it's possible to really do much to the stock manifold (apart from siamesing the ports). When I was replacing my stock baseplate with the Edlebrock, I simply took a look at the difference in port sizes (after I was done porting out the Edlebrock base to match my Accel LTRs), and I knew that there was no way that I could've done the same amount of port work to the stock baseplate. There's just not enough meat to enlarge the ports to really make a difference (even if you could port match to the Accel LTRs, you'd be better damn good so as to not hit that point of no return)
Old Dec 7, 2002 | 08:03 AM
86IROCTHD's Avatar
Car: 88 Trans Am
yea i know what u mean if i was to port it to the same size i would have to play with the gasket to get i to sit alittle different i dont know yet but i am already doing the upper plenum and going to do alittle bit on the runners so i will post up pics when i am done.....
Old Dec 7, 2002 | 10:34 AM
Morley's Avatar
Can't port a stock manifold to the bigmouth gaskets, not and have any material left on the manifold.
Old Dec 7, 2002 | 01:32 PM
86IROCTHD's Avatar
Car: 88 Trans Am
huh?
Old Dec 7, 2002 | 02:14 PM
Morley's Avatar
Originally posted by 86IROCTHD
huh?
If you try to port out a stock manifold to the bigmough size you'll run out of manifold, as in you'll remove too much metal.
Old Dec 7, 2002 | 02:51 PM
86IROCTHD's Avatar
Car: 88 Trans Am
ok thats what i thought u were trying to say
transaero
Aug 31, 2015 01:14 AM
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
