Starter problems
Old Dec 8, 2002 | 06:43 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
Starter problems
Hey guys, I have a problem with my 88 GTA starting.
I stopped by a friends house after work and when I got ready to leave the car would not do anything when you turn the key.
It has a new battery so I know that is not the problem.
You can jump the selonoid and the car turns over fine and starts with no problem. I also replaced the starter and selonoid and tried a new key thinking maybe the chip was bad but nothing changed.
Any suggestions on what to try next?javascript:smilie('')
Old Dec 9, 2002 | 08:32 PM
anybody have any ideas?
Old Dec 11, 2002 | 02:35 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Did you try asking in another forum other than
TPI?
Get a Helms manual and go thru the
wiring from ignition to solenoid... Make sure all
the battery & starter cable connections are
clean and tight.. Check the fusable links..
mike
Old Dec 11, 2002 | 06:47 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
I have a 92 Z28 and am having the same problem.
You my need a remote selinode.
Old Dec 11, 2002 | 07:09 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You also may have a bad igntion key. Your car has the VATS (Vehicle Anti-Theft System) thes keys do get worn in time and can loose contact, causing small starting problems at first that turn into... my darn car won't start period anymore. My bet is the key. The little resistor is probably wearin gout on you. It's worth a look anyway before you go buying parts you don't need. I have seen this problem many times in my day. Confuses alot of people to, so don't be suprised when you find that this may be your problem. HTH
Keiran
Old Dec 11, 2002 | 07:39 PM
Z03Z28's Avatar
My Z is fine when cold but when at operating temp
it won't start,unless I let it sit for a while.It does the
same with my new key,also I replaced the vats module
last year.I don't drive it much so I havn't looked into
the problem like I should have.I was going to just put
in a new starter.But I'd like to fix the problem.
Thanks to all who try to help.
:rockon: :rockon:
Old Dec 11, 2002 | 08:18 PM
I thought about the key also.
That was the first thing I tried but it makes no difference.
So far I have tried a new key, new starter, new selonoid, and new battery with no changes.
For the time being I have a starter button wired to the selonoid and it starts just fine that way but I would like to fix this problem.
Thanks for the help
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
