timing
Old Dec 9, 2002 | 02:10 PM
Brian'sIROC's Avatar
timing
Where should the timing be set at when idleing for an 88 305 TPI with the advance plugged in. Also about where should total timing be at WOT. What could cause the timing to be too far advanced? My base is set @ 6* BTDC.
Old Dec 9, 2002 | 05:15 PM
I was getting 35* advance at idle, I think thats too high.
Old Dec 11, 2002 | 09:25 AM
anybody know?
Old Dec 11, 2002 | 10:31 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I think that's in the right ballpark
Old Dec 13, 2002 | 07:01 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
Will too much advance cause the car to buck and hesitate at WOT?
Old Dec 13, 2002 | 08:15 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Too much advance will cause the car to ping. Sounds like you may have another problem. Did you do any other work on the car recently or were you just checking your timing?
Old Dec 13, 2002 | 08:49 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I may not have actually gone WOT before the mods so it is difficult to say what may have caused this problem. But this is what I have.
I have a 1991 TA TPI 305 w/5 speed.
It is modified with:
SLP headers and 3" exhaust
Crane Cam
SLP intake runners
SLP air foil
SLP High Performance chip
Crane roller rockers
TPIS big mouth intake
Accel 23# injectors
AFPR set at 47 psi
Racetronix high flow/pressure fuel pump and wiring harness
New fuel filter
All new ignition items (wires, cap, rotor, etc)
Jacob's Pro Street Ignition
The car is very fast and responsive except at WOT.
At WOT the car jumps and hesitates. Right before WOT everything is fine.
What could be causing this?
I am going to put my stock chip back in to see if the advanced timing is a problem or maybe something else with the chip?
I already put the ignition back to the stock coil and it didn't make a difference so it is not my Jacob's Ignition.
I am really puzzled.
I am thinking I need to do some tuning with the injector constant in the prom or some other programming because of the extent of my modifications.
Thanks for any suggestions.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
