Any difference in TBs from ....
Old Dec 10, 2002 | 01:12 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
1985-88 and 1989-92 TPI Camaro/Firebirds? Were the throttle cables different?
Old Dec 10, 2002 | 01:31 AM
Guest
Guest
Posts: n/a
Yea, they are different. One has a groove and a cam sorta deal, the other just clips in place.
Old Dec 10, 2002 | 09:03 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Damn. I guess 89-92 has the cam (which is what I have stock). Do you know if I can modify my throttle cable to clip on to the 85-88 style?
Old Dec 10, 2002 | 10:52 AM
Guest
Guest
Posts: n/a
Just a guess, but its probably just a matter of swapping out the throttle cable assembly to the earlier style.
Old Dec 10, 2002 | 03:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Another difference is the IAC passages are different to match TB to plenum
Old Dec 10, 2002 | 03:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
BTW, I have a spare one off an '88, I'd swap you for the '89-92. I'm only an hour or so South of you.
Old Dec 10, 2002 | 08:33 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
8Mike9:
The IAC passsages on the back are different for the aftermarket TBs too? The reason I ask is because the SuperRam plenum is the same for ALL years so it should match up with either TB. I should be OK unless I use my stock plenum (right?).
The TB I bought is for an 85-88 so it looks like we're both in search of the same part (89-92). I'm gonna try to get an 85-88 throttle cable tomorrow to see if it works.
Old Dec 10, 2002 | 09:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn, I don't know about the SuperRam, just the stocker.
Good luck.
69GTOby
Apr 18, 2016 02:34 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
