Fuel Pump
Old Dec 12, 2002 | 12:17 PM
LiQuido0's Avatar
Fuel Pump
The fuel pump in a 1986 TPI Trans Am is located inside the gastank and is an electric pump correct ?
Old Dec 12, 2002 | 03:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes.
Old Dec 12, 2002 | 05:44 PM
LiQuido0's Avatar
Ok I ran into somthing interesting, my fuel pressure check says its reading about 9-11psi, also my check engine light is giving this code.... Flash, Pause, Flash, Flash.
Does anyone know what that means ?
Old Dec 12, 2002 | 05:47 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Thats code 12. I forget what it means, but basically, if you see it everything's okay. If you don't see it then you have problems.
Old Dec 12, 2002 | 05:48 PM
LiQuido0's Avatar
Crap, ok any ideas why my car dies after starting ? it putters down.
Old Dec 12, 2002 | 05:59 PM
LiQuido0's Avatar
Also the fuel pressure is only reading 9-11psi
Old Dec 12, 2002 | 08:46 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
your fuel pressure is way low, it's supposed to be 40+. bad pump or pressure regulator maybe
Old Dec 12, 2002 | 08:54 PM
Bort62's Avatar
Your pressure is Way Low, Dude.
That code is code 12, No dist ref Pulse wich is totally Normal.
However, it will flash 3 times before displaying any other codes so be sure to go through the entire cycle.
Looks like you have a fuel pump in your future.
Old Dec 13, 2002 | 01:22 AM
LiQuido0's Avatar
Ok great, thanks guys, i'll take care of the pump in the morning, hopefully that'll do it then.
Old Dec 13, 2002 | 08:39 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Yeah the sputtering and such is from low fuel pressure. Check your fuel filter too. Give the cheap solutions a try first.
Old Dec 13, 2002 | 12:00 PM
LiQuido0's Avatar
the fuel filter was one of the first things i tried,
Old Dec 13, 2002 | 12:02 PM
LiQuido0's Avatar
Ok this sucks, how the hell am i going to get to the gas tank, the mufflers it totally in the way, and some other ****....
Old Dec 13, 2002 | 12:14 PM
Car: '87 Camaro LT
Engine: 355 L98
you have to remove the exhaust and lower the rear end by removing the shock bolts, but dont let the brake lines break. the filler neck on the tank will cause you some trouble in removing the tank, you have to fish it out and possibly bend it a little. do a search on removing the tank for more details, i have never done it
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
