Piston-valve clearance on 305 TPI
Old Dec 13, 2002 | 12:05 AM
rockind78's Avatar
Looking at cams for the motor I bought this summer. Question is:
Have any of you guys run into piston-valve clearance issues with your motors when doing the cam swap? Just wondering how much room I have to work with...sorta speak. Thnks guys!
Old Dec 13, 2002 | 12:31 AM
Guest
Guest
Posts: n/a
Piston to valve clearance... I dont think you'll run into any problems there.
What sorta lift you looking at?
Old Dec 13, 2002 | 12:41 AM
rockind78's Avatar
Not really sure yet. I picked up a set of Vortec heads at a good price. I was gonna have 'em milled and use a converted LT4 intake for induction. However, I don't wanna have machine work done to my heads for more lift (I think they will take around .480 or so) if I am limited by piston-valve clearance. I was actually just wondering if anyone had any problems with it. I had a friend kill his carbed 305 in his Caprice that way....though he was less than remorseful it seems like
Old Dec 13, 2002 | 01:37 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
not vortec heads
I ran this cam -> 217/225 .505/.525 with factory heads and pistons in an L03. No problems.
RP.
Old Dec 14, 2002 | 07:43 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I am running vortec heads and a ZZ-4 cam with 1.52 rockers which ends up at .480 intake and .515 on the exhaust. I am also running a .015 thick head gasket and my piston to valve clearence was .105 on the exhaust and more (can't remember the number) on the intake. You should not have any problems but don't take my word on it, you still need to check.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
