After Change of Wires and plugs...
Old Dec 13, 2002 | 10:58 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
It idles at 600 in drive and 600 in park before it idled at 700 in drive and 1100 in park. What could I have done? Or what could be the culprit?
Thanks, Gary
Old Dec 14, 2002 | 01:15 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Is it smooth at 600 RPMs? If so then you may have fixed a problem
Old Dec 14, 2002 | 09:19 AM
Engine: L98 350
Somewhat it seems a little smoother but it should be at a higher idle in park, it almost dies when i put it in gear now. I think someoff it is timing just have to find out in a little bit. and it seems like something is holding it back at part throttle.
Thanks, Gary
Old Dec 14, 2002 | 10:20 AM
kevinc's Avatar
Car: 1982 Z28
What did you set the plug gap to? Mine makes a big difference just between 0.035" and 0.045", it likes the 45 much better.
Old Dec 14, 2002 | 06:41 PM
Engine: L98 350
I set them at 45 after reading a few posts on here before thwey were 35
eightsixseven
Dec 16, 2024 01:50 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
jbd1969
Aug 17, 2015 07:06 PM
Zachattack0925
Aug 12, 2015 09:52 PM
