What injector will work the best?
Old Dec 15, 2002 | 10:46 AM
jonarotz's Avatar
Car: 91 Z28
I have a 91 tpi 305 right now, looking to put in a 355 in a year or so. I need injectors now and would like to get a set that will work good for both motors. Is there any that would work good for both? Is 24 lb/hr too much for a little 305?
Old Dec 15, 2002 | 04:26 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
24 lbs are too much for a 305 unless it's highly modded.
Old Dec 15, 2002 | 04:57 PM
True Power's Avatar
What he said. However, i'd get them, and just deal with the lack of good performance until the 355 goes in. No use buying, say new 19 or 22lbers for the 305, then going out and buying 24lbers for the 355.
Old Dec 15, 2002 | 07:34 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Are your injectors bad? If you put 24# injectors in now you will have more than just poor performance. Read several posts on this same subject. You're going to be pumping 25-30% more fuel in than the computer is aware of. You can get injectors on eBay for a fairly good price.
Old Dec 15, 2002 | 08:15 PM
jonarotz's Avatar
Car: 91 Z28
Well I took the plenum off to polish it and I needed new intake gaskets. While I have it a part I ohm checked the injectors all ohm out whithin specs except for one. I have noticed a slight miss so I figured that this could be the culprit. In the future I want to put a 355 in instead of the 305. so instead of buying a new set of 19lb injectors I was just wondering what could be a better option. Should I just replace the one? will there be any flow differences to worry about? The injectors I am running have 85,000 miles on them.
Old Dec 15, 2002 | 08:17 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
http://www.cruzinperformance.com/
Check out them and just get that one rebuilt.
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
