Porting & Polishing
Old Dec 16, 2002 | 11:09 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Porting & Polishing
Around how much does it cost to have pluenum and runners ported and polished? I have been thinking about getting it done to dress up my engine bay a little along with some new valve covers. Any info would be appreciated. Thanks!
Old Dec 16, 2002 | 11:44 PM
tiggermanoman's Avatar
You spoke of dressing up your engine bay. I ask if it is performance your looking for or someone to polish runners (externally) and plenum. I have a friend who polishes for Street and Performance in Mena, Arkansas. I'll have to ask him how much he charges. He does work on the side. Now if your looking for what you actually asked "port and polish" then save your money and buy a arbor kit and die grinder after pulling apart and get with it. When doing aluminum I use some parfin gulf wax on my bits which keeps the aluminum from building up on the tool and actually sends the slivers of aluminum flying when they stop flying recoat with wax and go again concentrate on the upper side of intake runners although not alot can be taken out but everybit helps. Same way behind the throttle body area. Gouge out eyebrows but watch out for bolt hole areas. Knock down until good smooth entry that is unobstructed is attained. I think if you look under search you will find some guys that take pictures and show you the process. Good luck. Hope you acheive your goals.
Old Dec 17, 2002 | 09:38 AM
Vader's Avatar
Plenum Porting.pdf
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Reid Fleming
Oct 10, 2015 09:56 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
