L98 350 Heads, Cam, 305 tpi expermintental build up
Old Dec 15, 2002 | 11:18 AM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
First off, you post a search comment and I'll slam your butthole good. I've been here long enough to know that.
With that comment out of the way here is the sitution. I have 350 L98 Heads, paid 100$ bucks for them, thought I could put them to some use.
I spent the weekend helping my friend to dismantle his 350 for a build up and learned alot tearing apart an engine. I have been planning my build up for some time, and I'm not building up a 305.
Aside from the point, my 305 has been rebuilt and is a good learning block to experiment with a few things.
I want to take the L98 350 Heads have them ported, polished, vavle job and decked, I will also have to have my intake shaved as well so it will fit nicely with the new heads.
I've read the facts and opinions on 350 heads on a 305, I know it will lower compression. This is why I am having them shaved a tad bit.
We also know that they will bolt up correctly, but we have all heard about cleance issues. I think this is somethign the machine shop can work out though.
I also have a rather very nice high lift cam for this motor.
My car ran 14.65. All I want to do here is push low 14.2 or so and then I can go find my block for the big toy I want to build.
If I could just get some opinions, and advice about what to look for.
I'm not spending mad cash here, just experimenting. Freebies and Cheapos
Old Dec 15, 2002 | 06:06 PM
L98Jerry's Avatar
I cant remember where I read it but I swear I read that the 350 heads wont work on a 305 because of the valves being spaced too far apart for the 305 bore. I may be wrong and I am no means an expert on this so take what I said lightly because I am not positive.
Old Dec 15, 2002 | 07:29 PM
87 B4Z's Avatar
from what i have read, the heads with the 1.94/1.54 valves will work.
Old Dec 16, 2002 | 07:29 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
with the lowered compression that'd be a good canidate for a big shot of the juice.
Old Dec 17, 2002 | 12:09 PM
chevy power's Avatar
I have a built 305, heads, cam ..ect. i have edlebrock performer heads for a 350 w/ 1.94 , 2.02 valves and it works fine. check out my mods in the sig.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
