y-pipe
Old Dec 17, 2002 | 08:11 AM
sprayed 88's Avatar
Car: 1988 Iroc-z
Engine: L98 350
Transmission: 700-R4
y-pipe
Does anyone know where I can get a y-pipe for single cat to fit a set of SLP 1 3/4in. headers.I found a good deal on a set but they are for dual cats.I'm told the only difference is the y-pipe so any help would be appreciated.
Thanks in advance,
Levi:hail:
Old Dec 17, 2002 | 01:47 PM
grumpyvette's Avatar
http://www.racerpartswholesale.com/flomstr1e.htm
http://www.exhaustproslinc.com/xandypipes1.html
http://www.exhaustproslinc.com/magmanbenyp3.html
http://www.burnsstainless.com/Crosso...rossovers.html
cut your old flange off the old pipe and use one of these to weld a (Y) pipe up to fit your needs
Old Dec 17, 2002 | 09:05 PM
Guest
Guest
Posts: n/a
They arent all that much different, I have one of both. I'd just have a shop y the two pipes into one, and hook that up to the cat. SLP will charge you an arm and a leg for the right y-pipe.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
