Porting TPI--difficulty??
Old Dec 17, 2002 | 08:55 PM
91 Camaro Z28's Avatar
Hey people-- I was thinking of porting my TPI myself before I put it on my future *built* 350 Is it worth the time and effort to port the TPI? Will I see noticeable hp/tq gains with it? Will the 305 TPI flow enough air to power the new high performance 350? Is the 305 TPI the same one that comes with the 350s? i'm a rookie so bare with me
-Justin
Old Dec 17, 2002 | 11:10 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ok the tpi is the same ont he 305 as the 350...there no difference expect the injectors...the 305's are 19# and the 350's are 22#....right inside the throttle body opening are two little walls that help "circulate" the EGR gasses..grind those down to the floor of the plenum and youll notice a slight difference in power and a little more throttle response....theres not much material to port out on the stock base so you cant really get into that...you can siamese the port openings and the effextivly brings the peak HP number up a few hundred rpms....
id say youll see a good 10-15 peak horse but a few more then that at higher rpms
Old Dec 18, 2002 | 01:15 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Worth it if you dont mind the work of the actual porting.
Not worth it if you can afford an aftermarket base/runners - as those will outflow a fully ported stock unit.
Old Dec 18, 2002 | 07:42 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the knock sensor is also different as is the 5.7 PROM.the car will run with the 5.0 PROM but it will run better with the 5.7 PROM.
Old Dec 18, 2002 | 08:42 AM
Elric's86-Z's Avatar
Where can I get a 5.7 Prom??
Mine was switched to a 5.7 from a 5.0, an just doesnt have all the ***** it should have,I think the injectors are from the 5.0 also.
Old Dec 18, 2002 | 10:39 AM
91banditt2's Avatar
Engine: 5.7 HSR
http://www.speedtoys.com/~bort62/PROM/
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
