Are LT1 intakes legal?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm in the process of tearing down a motor, and I'm considering possible choices. I was thinking maybe TPI, since I already have a TBI computer, and that can be made to workl for TPI right? I also saw LT1 intakes and such. Are these legal? My car will be my daily driver, and will be inspected, and fuel economy is an issue also. But I'd like fuel injection. I was also thinking of 383, would a carb be the only induction setup to feed a 383?
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
No one has done it yet. If you take the TPI corvette for example, the EGR has an outside system. SD vortec intake has the parts to make the same system work. How it works, you ask? The EGR system, instead of running through the ports in the head, uses a piece of piping to route it up to the rear of the intake manifold. I am pretty sure that it how the 4th gen cars do it. The LT4 intake uses the same piping but has the EGR system inside of the manifold, somehow. Please double check the LT4 system, for I am not 100% sure of this. If someone was to come up with a way to do it, people would purchase more intakes. I'm sure that John Millican will chime in shortly, I have had many conversations with him on this.
The problem is that the EGR is on the rear of the intake, it would need to be removed for use with the distributor. That is why it wont be street legal and wont be legal with visual inspections. Some people just use the block off plate on the old TPI systems and have passed the emmissions test. Your choice.
Guest
Posts: n/a
Well here it wouldnt be legal, because that intake was never available on a normal SBC engine. You'd have to sell it to the state guys as a SBC with a LT1 intake (that'd never work), or as an LT1 engine (which might work, but unlikely).
I dont know how it works up in your neck of the woods.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
If you are refering to a LT1 intake on a SBC then the simple answer is "no".
As you may know the EGR valve and external exhaust feed needs to be removed to make room for a standard distributor. So if you have a visual inspection you will fail.
There is a good chance you will also fail if you put a carb on there as well since it wasn't available in your car model year.
And as far as LT4 intakes and EGR system, I have no idea. I have never seen a LT4 intake in person but I suspect it has the same EGR as a LT1.
Car: Kitt
Engine: Classified
Well, so if it didn't come in my car stock, it isn't legal? So, I'm guessing a Superram wouldn't be legal either huh? I ask this, because I'd like to build a 383, and I'd like EFI with it. Those are the only options I've seen that would support a 383. Is this right? If not, forgive me, I'm still learning. Thanks
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You could put a NEWER motor in your car (such as a complete LT1) and they would have to smog it based on the specs for that motor but you can't put earlier equipment or parts that were never made for that car (i.e. Can't put an L98 in to a 4th gen). What state do you live in and how tough are the inspections?
Car: 1990 Iroc-Z
Have you considered making a High Flow TPI setup instead?
That'd be completely legal.
Port the upper plenum and portmatch to runners
High flow runners of course (SLP siamesed or Large tubes)
Aftermarket base like the bigmouth/edelbrock or maybe even the Superram base.
I imagine a tpi setup consisting of these parts would flow as good or damn close to the popular aftermarkets (stealthram, superram, lt1, mini etc) Also, I happen to think that the long tube runner system looks badass, especially when polished up!
Car: Kitt
Engine: Classified
I live in Texas. So, a superram and a high flow TPI would be
legal? I can imagine a TPI would, because it came in our cars. But the superram is also? Well, if I do all that you said to a TPI system, wouldn't it cost as much as a superram? You can't tell my 'older' 350 from a newer one from the outside right? So the fact that I would have an older 350 in my thirdgen wouldn't matter right?
If you have ever bought items like the Superram or high flow parts, you'd know that it comes w/ a sticker that must be in plain view to the emissions *****. The sticker identifes the part and gives its CARB approval number. I have one for my Trick Flow heads and my Superram lower intake manifold. Thats how these parts are smog legal. Of course I don't have emissions are inspections where I'm from, so I don't know why I saved them...
Car: 1990 Iroc-Z
Yes a high flow TPI system would be legal even under visual inspection. Since it's stilla TPI setup, and looks stock to anyone who isn't into thirdgens... I dont imagine a visual inspector would notice different runners/lower intake mani.
Aftermarket runners - 250ish
Aftermarket base - 450ish
Ported Plenum - "Free"
250+450+0 = 700 give or take.
Superram = 1100 give or take
400 means a lot to me i dont know about you =)
If you already have a computer, you can get the Stealth Ram for $550. Keep in mind that the Stealth Ram is not emissions legal and I've heard that ported plenums with the EGR walls knocked out have trouble passing smog as well. I'd say that the SuperRam is the best way to go, but it's pricey ($1200). It's up to you. Personaly, I think that the Super Ram is the best, but I want to pass smog, so I'll probably get a SuperRam.
TPI in TX
I am from TX too and I have a TPI in my monte carlo SS. It is amazing what these guys will pass. The inspection guy did not even take a second look or say anything about it. All the smog equipment is there and it is completely street legal.
The super ram is the easiest way to go and be street/emissions legal. D stroy H8 shows the difference in price but did not mention the "tuned" difference of the "stock" style TPI vs the super ram. Super ram has shorter runners which has a different "tune" giving it a higher RPM HP peak. The super ram is much better suited to track applications. A ported/aftermarket TPI system is better suited to more power in a stop light to stop light application of just out cruising. HTHs
Personaly, I think that the Stealth Ram is the best, but I want to pass smog, so I'll probably get a SuperRam.
Car: 1990 Iroc-Z
Well yeah the Superram is better, I don't disagree...
However the TPI stock style with portmatched plenum/runners/base, SLPs siamesed OR large tubes, edelbrock base OR superram base I think would hit some high RPMs comparable to the Superram, and also keep all that nice low end torque just like the Superram.
So what Im saying is - A high flowing stock style TPI setup would perform nearly as good as a Superram.
For nearly the same amount of money. (400.00 less)
Car: 1990 Iroc-Z
Not just ported and polished.
When I say 'High flowing TPI setup" I mean Aftermarket base and runners. No way will the TPI ever perform close to a Superram with stock runners and base.
The aftermarket offers runners that can literally SWALLOW a stock runner, and bases that flow MORE than a fully ported stock base out of the box. If you want, you can FURTHER port out an edelbrock base or a bigmouth from TPIS.
So the question is - Do I think a ported upper plenum portmatched to SLP's siamesed runners which are in turn portmatched to an Edelbrock lower manifold would perform nearly as good as a Superram?
The answer is - Yes. Yes I do.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
