Engine Hunting for Certain RPM
Old Dec 20, 2002 | 05:13 PM
1BADAZTA's Avatar
Can't figure this out. It's a fully modded 305 and modded 700 r4. I put the car in gear and the rpm's fluctuate between 650-850 and doesn't settle. I checked the usual possible vaccum leaks, just did a tune up, tapped on the MAF(nothing happened) no codes, can't figure it out. Not a daily driver, just use in spring through fall. It does this when cold or when warmed up. Any ideas please feel free. Thanks.
Old Dec 22, 2002 | 07:45 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
this isnt goin to help any but I had a similar problem when idleing. Does it bounce all over the place or does it slowly go up then down back and forth... Cause my 305 TPI had a tach where it would bonce all over the place between 550 and 900 and all I did is replace plug wires and it went away but if you have already done a tune up then I dont think it could be the wires.
eightsixseven
Dec 16, 2024 01:50 PM
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
