airfoil
Old Dec 24, 2002 | 12:44 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
Transmission: 700-R4
airfoil
Is there any difference in the different tb airfoils on the market other than price? Does anybody have a particular preference.
Old Dec 24, 2002 | 02:17 PM
Z28DJP1987's Avatar
Just buy the cheapest one, they all perform the same function.
Old Dec 24, 2002 | 04:27 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well - I don't know for sure.
I bought a generic one, and it isn't metal it's plastic. The part that cuts the air flow to reduce turbulence is somewhat blunt... I alwasy thought that foils had sharp edges cause that made sense to me.
Old Dec 24, 2002 | 05:34 PM
Z28DJP1987's Avatar
There still all the same, you want sharpe put a razor blade in there.
Old Dec 24, 2002 | 06:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Hehe dont roll your eyes at me!
I was just questioning, whether or not anyone knows if all the foils are sharp or blunt or what have you, cause if they aren;t then one of the two must perform better.
Old Dec 24, 2002 | 08:18 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Originally posted by Z28DJP1987
....they all perform the same function.
Yes... paperweight.
Old Dec 24, 2002 | 10:40 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I disagree with that.
Flow bench testing has proven that an airfoil will allow around
12-20cfm more in a stock 48mm gm throttle body.
Old Dec 25, 2002 | 07:57 AM
Sciguyjim's Avatar
blunt airfoil
In my research, I found that a slightly blunt airfoil, or even jet or rocket nosecone, was preferred for subsonic speeds. When supersonic speeds were to be encountered, then a sharp point was the preferred shape.
Old Dec 25, 2002 | 02:36 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
airfoils really do make a difference..obviously not much, u can barely notice it but after i put in mine, my car accelerated smoother..really..worth the money i think
Old Dec 25, 2002 | 04:14 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Ok then! So I appreciate that subsonic supersonic reasoning. My mind is at ease now =D
I figure with the dual snorkel intake, an airfoil with cut airboxes should be a nice little mod. Ready to compliment a high flow TPI setup.
Old Dec 26, 2002 | 05:26 AM
MdFormula350's Avatar
i have the tpis one i think..
Old Dec 26, 2002 | 01:13 PM
Drew's Avatar
In my opinion they're all about the same, the only difference is in the materials they're composed of and how they're retained in the throttle body. Avoid the JET, Holley, and other composite airfoils. I'd also avoid the generic no-name pieces that are sold on ebay. Stick to SLP, Hypertech, and TPIS... They're all aluminum and held in place with a screw/nut.
As for the shape effecting performance, I doubt it. All you're trying to do is smooth the flow of air in the throttle body. GM left a large open space between the bores to channel air into the IAC passage. By installing an airfoil you're making the passage smaller and giving a more aerodynamic method of letting air into the throttle bores. As long as the air doesn't hit an edge it can't move around easily, it'll be fine. Flat spots are what you want to avoid. Any of the airfoils will be better then the stock configuration, but none of them are going to be enough better then another that any of us will ever feel it when we launch at a stoplight.
Old Dec 26, 2002 | 03:34 PM
Morley's Avatar
Yes, avoid the composite ones like the plague. Carbon composite and alumnium do not behave well together, the alum will begin to corrode at an alarming rate.
Old Dec 26, 2002 | 04:07 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
is the comp cams one included in that list. I believe that it is a plastic composite similar to the ls1 intake manifold.
kairles
Oct 26, 2015 09:13 PM
vortech305
Aftermarket Product Review
Dec 5, 2001 02:01 PM
J's86ROC
16
Nov 14, 2001 11:42 AM
Camaro92
Mar 13, 2001 02:45 PM
hookin88formula
Oct 16, 2000 11:25 PM
