Intake manifold holes
Old Dec 24, 2002 | 05:17 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
On the base manifold, TPIS big mouth there are holes, 4 of them, in between the injector bosses. I am wondering if they cause a vacuum leak if left open. I was reading a back issue of a magazine that the Accel base manifold has similar holes and according to them if the holes are left unplugged they will cause a vacuum leak.
I am wondering about the TPIS piece because I noticed on a scanner that the vacuum is showing at idle 14 inches of vacuum. That is much lower than I would expect with the cam and other componets of my engine. I would think the engines would have 16-17 inches of vacuum at idle.
If anyone has any idea about these holes let me know
THanks in advance.
Old Dec 24, 2002 | 07:12 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
i would take a mechanical vacuum gauge to verify the vacuum you are getting.
Old Dec 24, 2002 | 08:24 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Intake manifold holes
Do you have a picture of these things? I'm wondering if they are the 4 holes that the studs that hold the fuel injector harnesses in place go into.
Old Dec 24, 2002 | 10:24 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I don't think so because my factory manifold doesn't have anything like that. My harness has a hold down that uses a different hole. These are very small, maybe a 1/16 of an inch or so in diameter.
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
