At the end of the 1/4 mile the car just dies....
Old Dec 27, 2002 | 01:19 PM
vortech305's Avatar
This was a slight problem i was having with my modded 305 TPI, its from an 87 with MAF. As i ran down the 1/4 mile and let go off the gas and putting it in neutral(5 speed) as i was braking the car would just die, then i would slow it down to 10mph then restart it. I would have to give it gas in order for it to shut down. As soon as i would drive it to get the ticket it would drive normal. Beyond the 1/4 mile the car would drive as if the problem never existed, any thoughts?
Old Dec 27, 2002 | 01:28 PM
Jza's Avatar
Jza
Sounds just like a dying fuel pump.
Old Dec 27, 2002 | 01:38 PM
IDOXLR8's Avatar
sometimes a MSD box will caus this they have a resister to install if this happens did you just install a MSD or other kind of multipl spark discharg box?
Old Dec 27, 2002 | 02:31 PM
vortech305's Avatar
I have nothing of MSD in my car. I was thinking of a bad fuel pump, but i installed a new remanufactured one about a year ago.
Old Dec 27, 2002 | 02:47 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
"NEW REMANUFACTURED", that could sum it up right there! IMO Look into a new pump or if you can not figure it out, take it to a shop and see what they say about it. good luck
Old Dec 27, 2002 | 03:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
MAF or MAF relay.
Cheap fix is to adjust your minimum air rate screw to open the throttle a little more at idle.
1992rs/ss
Jan 31, 2025 05:10 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
kyle5647
Aug 7, 2015 03:08 PM
3rdgenparts
Aug 6, 2015 09:03 AM
