what problems would arise with a non working EGR?
Old Dec 27, 2002 | 08:38 PM
vortech305's Avatar
I pretty much understand the basics of the EGR system, But what would resullt in a non working EGR? Im sure Combustion temperatures would increase, so could this be repaired by adding a cooler spark plug range?
To make a long story short, Im using 88' vette heads which doesnt have a port for the EGR and using edelbrock intake manifold which also dosent have a secondary port for the EGR. I've been checking my Spark plugs and they've been coming out hot, so i guess this is the culprit, There isnt any vacuum line attached to the EGR, so can i leave it at that and just add a cooler spark plug range?
Old Dec 27, 2002 | 09:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The only thing I can see happening, is the SES light maybe coming on...if so, have the prom burned to diasble EGR diag's and functions/codes...as far as performance is concerned, just tune the engine as is and be done with it.
Then again if you have a functional smog test, your screwed.
Old Dec 27, 2002 | 10:12 PM
vortech305's Avatar
i have no smog equipment.
1992rs/ss
Jan 31, 2025 05:10 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
