do i need a 14 or 15 gallon tank
Old Dec 28, 2002 | 11:17 AM
Electromaro's Avatar
please help. i am doing a lt1 swap from my 87 lg4 z28. i need to replace the gas tank and i'm not sure which one to get. i know that i need a tpi tank with the pump in the tank. but i went to the parts store and they had a 15 gallon tank and a 14 gallon tank. one with a filler neck, and one without. would either fit?
Old Dec 28, 2002 | 12:06 PM
please help
Old Dec 28, 2002 | 12:56 PM
4L60bliss's Avatar
I thought there was only one for these cars: 15 gallon w/ filler neck.
Old Dec 28, 2002 | 02:02 PM
Bort62's Avatar
No reason to remove the Lg4 tank, jut get the TPI fuel ender assembly.
Old Dec 29, 2002 | 01:53 AM
i need the tpi sender unit, but that is an in tank pump. i don't know
Old Dec 29, 2002 | 07:14 AM
4L60bliss's Avatar
What he is saying is that all thank fuel tanks were the same, regardless if the car came with carburator, TBI or TPI. Its the sending unit thats different. The TBI/TPI cars came w/ high pressure fittings on the end, the Carb sending units did not. If your tank is not damaged, then you can just replace the sending unit, since that is what the pump is mounted to.
gta892000
Aug 11, 2019 11:16 AM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
