Edelbrock TPI Manifold
Old Jan 4, 2003 | 08:59 PM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
This manifold , Jegs #350-3860 , has anyone used it ?? How would it be on a 305 with mild cam upgrade , stock runners and ported heads, ported plenum?? How does it compare with other aftermarket or stock ported manifolds??? Any input would be great !!
Old Jan 5, 2003 | 02:59 AM
rezinn's Avatar
I've got it. Basically every other manifold is the same, except the accel. The only better one is the scoggin dickey intake, which is used for vortec heads. The TPIS used to be a ported edelbrock manifold, but I've heard they're just selling edelbrock's manifold unported now. As far as "how would it be," my only answer is that it'll work fine. You won't get the full advantage of it without porting, which is true of any manifold. No point getting it if you've still got stock runners since you can only move as much air as the smallest part of your intake.
Old Jan 5, 2003 | 08:29 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Rezinn, Since you have the intake, I have a Q for ya. If I were to go with Alum. L98 heads, they have no passage for EGR, which is why vettes use an external crossover. I think on Vettes, the tube ties in to the back of the intake. Does the Edelbrock have the passage in the back? If so it prolly has a block off plate on it. If you can check i would appreciate it a lot.
Old Jan 5, 2003 | 11:54 AM
Guest
Guest
Posts: n/a
Yes it does have the vette EGR hookup.
Old Jan 5, 2003 | 04:30 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Sweet, then i will have no problem using the L98 Alum, heads, all I need is the EGR kit from SDPC. Seems for the $$$ the edlbrk intake is the best bet, with a lil porting.
Old Jan 5, 2003 | 04:52 PM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
BUT IT WILL BOLT UP YO MINE WITHOUT HAVING TO CHANGE THE EGR RIGHT ??
Old Jan 5, 2003 | 08:49 PM
Z_Ghost's Avatar
Yes it will boilt up just like the stock intake does.
91TPI5.7 has corvette aluminum heads and they do not have the exhaust cross over in them.
The only difference between the 305 and the 350 is the 305 have smaller pistons.
Old Jan 7, 2003 | 09:48 PM
CAMAROPRO5150's Avatar
Car: 88 Trans Am GTA..
Engine: 355 TPI, DONE to the gills
EDLEBROCK INTAKE
WIL THE EDLEBROCK INTAKE WORK WITH ALL 3RD GEN CAMARO HEADS? 82-92..CAUSE THERE ARE SOME DIFFERENT ANGLES OUT HERE
Old Jan 7, 2003 | 10:15 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
yes they modified it to accept both patterns.
Old Jan 11, 2003 | 03:42 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
What's different abt the Accel intake?
Old Dec 10, 2007 | 02:13 AM
camarotwofast's Avatar
Re: EDLEBROCK INTAKE
no you have to buy the right one there are two edelbrock tpi manifolds one for perimiter bolt valve covers and one for 87 and up centerbolt valve covers!
Old Dec 10, 2007 | 03:00 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
the TPi was designed for GM's flagship motor which was gona be the 305 that was to be the HIPO option throughout all 3rd gen carmaro's and firebirds. the TPI was never intended for 350's, that all changed when GM started putting the 350 that was in the vettes in the formula 350's, IROC's, of course it was rated at a lower HP number so that there wouldnt be any competition with GM;s/chevys sports car the vette. The TPI isnt all that restrictive on a 305, it really begins to choke the 350 of course thats bc of the 4"bore and 45 extra cubes. to put a highflow edelbrock base on a mild cam 305 with ported heads, stock runners and ported plenum isnt really gona give u all that much, i would keep the 400$ that u would waste and put it towards something that will give u more HP per $. u would gain 5 hp maybe with the base, bc of the runners... think about it the 350 only gained 20hp with the base and runner upgrades. the intake isnt choking your motor really. its just limiting your RPM which is bc of the length of the runners not the runner size, porting with a set of siamesed runners will increase plenum area and increase RPM powerband, porting will help tho with the stock stuff. i wouldnt get the intake with your setup. i would port the stock base and work it out nicely and just save for sum runners down the road. a ported stock intake is more than adequate for ur setup, and setups more advance than urs on 305s. **** i mean a stock TPI on a stock 4 bolt truck 350 from a junk yard with twin buick 3.8 buick turbos is puttin down 542 rwhp. i think ur good lol
supposidly the edelbrock intake is just stuck in the ACcel box and accel sells it for alot more. some guy posted pics of an edelbrock base in an accell box lol he was pissed and so would i. TPIS's big mouth is way to much for ur motor. but they work the base i think they get it from AS&M with there large tube runners, not sure. the only other good base is the vortec base from scoggin but u need vortec heads.
in consencus i would port ur stock base nicely, port match all the gaskets etc, if u want get a set of aftermarket runners used or just throw the money into the motor, get a set of 305 SR torqer heads. those set with a mild cam made 50rwhp on a stock 305 TBI 3rd gen camaro in CHP, with exhaust upgrade. or another set of heads for your 305.
make sure u get the right base if u still decide to, im not sure if they sell one for both valve cover configurations.
Old Dec 10, 2007 | 03:47 AM
Guest
Guest
Posts: n/a
Tsk tsk tsk. Revive an old post to put up incorrect information.
Edelbrock #3860 base is machined to fit either style head.
Old Dec 10, 2007 | 04:17 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Edelbrock TPI Manifold
I have a 3860 NO ITS NOT FOR SALE
It will fit early heads or late head as well as corvette heads
It has provisions for drawing egr conventionally through the heads or through a egr tube like a corvette has
it is drill and tapped to accept eith corvette or F-body fuel rails
it's drilled and tapped to accept three screwed in sensor at the front of the manifold (cold start temp sensor, coolant sensor, throttlebody heater hose fitting)
has a boss for the f-body alternator brace
In short gentlmen the 3860 will fit ANY small block chevy from 91 down and have full emmisions capability for whatever heads you run
Old Aug 9, 2023 | 02:22 PM
raphael's Avatar
I just bought it and for some reason the coolant sensor will not fit in the hole it appears smaller any suggestions it is 3/8 size of sensor
Old Sep 21, 2023 | 09:14 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
I had one- it was JUNK! None of the intake ports lined up right and had all sorts of air leaks.
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
