MAF restriction?
Old Jan 5, 2003 | 11:57 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
MAF restriction?
I am just about ready to button up my motor and am ready to get a chip burnt for it. I was thinking about how big of a restriction the MAF is, and I also read an article recently about a modded 396 that gained a ton of HP when they changed to DFI. My question is this...
Is it worthwhile to convert to SD?
If not, what are the other affordable alternatives?
My car is an '86 IROC-Z, the motor is a 383, and it has TFS heads (going to sell my aluminum vette heads), cc306 cam, modded LT1 intake, 1.6 roller rockers, all high-flow TB and fuel components, borla exhaust, headers, and a T-56. So it should pull in quite a bit of air. Anybody have experience with this?
Old Jan 5, 2003 | 01:05 PM
MdFormula350's Avatar
you can modify the maf... cut the screens out on both sides.
Old Jan 5, 2003 | 05:15 PM
85l98's Avatar
my 406 has run a best of 11:1 et at 124 mph it doesnt become a restiction till you go bottem 10s or high 9s
http://hometown.aol.com/corkvette1/myhomepage/auto.html
Old Jan 6, 2003 | 11:08 PM
dhirocz's Avatar
I did everything I could possibly do...descreen the MAF, trim half the fins (wanted some heatsink), cut the lip on the inside of the aircleaner down, all that stuff. Wish they made smooth bellows for thses things. Anyway, I was just told that the MAF imposes a huge restriction over 400 HP. So I'm wondering if I should save the money and step up to DFI?
Old Jan 6, 2003 | 11:48 PM
85l98's Avatar
go read this thread
http://forums.corvetteforum.com/zerothread?id=466269
Old Jan 7, 2003 | 02:57 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If you want more flow go for the Wells SU-145 MAF...........
Old Jan 9, 2003 | 05:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by 85l98
go read this thread
Vette Forums are always, ugh, well, interesting.
The LS1 and 3.5 LT1 MAFs are accurate to 512 gm/sec..
It would be hard to imagine GM risking a few thousand engines on calibrations that weren't accurate. Not that anyone hammers on the 4th Gen F bodies, or C5s.
Mark_ZZ3
May 24, 2018 01:02 PM
cheesehomer
Dec 31, 2015 08:48 AM
racereese
Oct 3, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
