People with stock pistons and AFR...couple questions.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Which AFR heads did you get. I am trying to decide between the AFR 190 heads with 76cc or the 68cc. I was trying to figure out what the changes were between the stock compression of 9.1:1 and what ever the outcome would be now.
TIA
TIA
Someone correct me if I'm wrong, but I believe every 4.19 cc reduction in combustion chamber volume is worth half a point in compression. That is, if you have 9.1:1 compression now, and your new heads had 4.19 cc less than your old heads, your new compression would be 9.6:1.
One other thing, if you're running TPI, the 190cc heads are going to be way too much. I'd opt for a 180 (AFR) or even a 170 (from Edelbrock). A TPI system will choke at the RPM's a 190cc head starts to shine. It'll be mismatched combination.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
