Coolant hose to tpi unit?
Old Jan 19, 2003 | 02:21 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
I have an annoying coolant leak that comes and goes when it pleases and i've linked it to a coolant hose that comes from the intake manifold and goes to the tpi unit. The hose on my car looks like someone replaced it at one point and obviously didnt use the right part. There is a major crimp in the middle of it and where it connects to the tpi there is no clamp either (which is probably why it leaks). Anyways, I wonder if theres any special hose I need and what exactly I need it for. Thanks
Old Jan 19, 2003 | 02:29 AM
llvll4l2c91350's Avatar
Sounds like you're talkin about the coolant hose that routes coolant to the throttle body to prevent freezing of the plates. Some people say this is useful in cold climates but I think the heat from the engine is enough to thaw out anything under the hood. You can bypass the throttle body and just connect that hose to the hose on the other side. Could also be considered a "free mod" as this coolant may heat up the air entering the engine, which is something undesirable if we're looking for more power output.
Old Jan 19, 2003 | 03:39 AM
T3am Z28's Avatar
Throttle Body Coolant Bypass Mod
I believe there is a tech article on it...
-LJ
Old Jan 20, 2003 | 12:38 AM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...ntbypass.shtml
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Sanjay
Aug 12, 2015 03:41 PM
