removing TPI harness
Old Jan 23, 2003 | 06:31 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
what all will i have to do to remove the computer, harness and what sensors will i need to take out as well? and is it easy?
Old Jan 23, 2003 | 08:08 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
very easy, remove the block from the firewall, it is held in place with a screw. Use a 1/4" to get the screw out. The harness is also held in place right where the interior meets the fender area with like a U clip sorta thing. That clip needs to be pulled up but it is tricky to get the thing to release. Everything else is pretty much straight forward.
Old Jan 23, 2003 | 08:36 PM
leirch's Avatar
As already stated, its pretty straight forward. Don't get in a rush and start pulling, its a pain getting the harness out of the fender opening, but work with it a little and it clears.
Brendan
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
