LT1 modded intake
Old Jan 23, 2003 | 09:38 PM
vwdave's Avatar
LT1 modded intake
Someone posted a link to a guy that modifys LT1 Fuel Injections to work on the 87- SBC's. I did a search, couldn't find it.
Help. TIA.
Old Jan 23, 2003 | 09:46 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
www.lt1intake.com
John Millican I believe.
There ya go!!
Old Jan 23, 2003 | 09:47 PM
vwdave's Avatar
Thanks.
For the hell of it, how much is a miniram? Do I buy TPI parts to swap it from TBI?
Old Jan 24, 2003 | 06:04 PM
86 IROC's Avatar
A new Mini Ram minus the fuel line kit is $855. John's site is down currently, be patient and it should be back online shortly.
Old Jan 24, 2003 | 06:08 PM
vwdave's Avatar
Thats it? TPIS wanted $3800. Talk about a un-lubed raping....
Old Jan 24, 2003 | 06:24 PM
86 IROC's Avatar
$855 is through TPIS. For $3800 you get: intake, throttle body, fuel line kit, injectors, ECM, harness, sensors, misc parts. You don't need the fuel line kit, there is a post about Mini Ram fuel lines on the TPI board. Look at the pictures in that thread. You can duplicate that cheaper than what TPIS wants for a kit.
Old Jan 24, 2003 | 06:38 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Don't buy the chip either! $575 is way too much. I bought one and found i could use any chip really, or even burn my own. So i was able to return it! A++ to TPIS for that one, very understanding. I was under the impression that i "needed" their chip. Also, i have heard that some have had bad experiences with their chips, and other had good ones. Don't know, never used it. Thats another place to save some money. Try fastchip.com good luck
Old Jan 24, 2003 | 09:55 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
As stated above, the manifold itself is $855 and a fuel rail and install kit for a thirdgen is $355. A fuel rail only kit is $295. Both rail kits come with an adjustable regulator, bolts, cross-plumbing, and the rails themselves. The F-body kit comes with all of the fittings and hard lines to make it a direct bolt on. So for a complete direct bolt on kit for our cars is $1210.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
fbirdroller
Sep 2, 2015 10:27 PM
1LE91
Aug 31, 2015 08:13 PM
