Stuck and broken TPI manifold bolts
Old Jan 27, 2003 | 04:52 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
I have a couple frozen manifold bolts and one with broken off head. What would be a good way to break them free without losing more heads? They are the torx style manifold base bolts. I thought about heating the block around the bolt but wasn't sure if that would be useful.
Any suggestions would be appreciated.
Old Jan 27, 2003 | 06:13 PM
Breadfan's Avatar
Go buy some PB blaster , way better than wesel dick (w.d 40).
Than tighten the bolt , than back it off . That dosn't work hope you have a drill ,some bits , tap set , and a helicoil. Good luck
Old Jan 27, 2003 | 06:50 PM
rezinn's Avatar
If you can't get them, just break the rest of the heads off or chisel them off, then pull the intake off and grab them with some channel locks. Then go to the hardware store and buy some real bolts.
Old Apr 28, 2003 | 10:49 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
ack
ok i found this thread using mr search and...
my question is simple. i got this TPI setup off a donor car, but its missing the bolts for the runners and plenum!
is there an easier way than trial/error with hardware bolts?
anyone know the size or correct length or a part # to get these things?
Old Apr 28, 2003 | 10:59 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've had extremely good luck using a pipe wrench to remove those stubborn stripped/broken bolts.of course after i had used a good amount of penetrant.
hectre13
Dec 11, 2023 08:14 AM
transaero
Aug 31, 2015 01:14 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
timonator
Aug 11, 2015 09:56 PM
