86 305 with an 88 350
Old Jan 31, 2003 | 11:32 AM
91 z28 350's Avatar
Car: 91 Z28
Ok my friend has an 86 iroc that originally had a 305 and he swapped in a 350 with new trick flow 23* heads. It is misfiring. Could the 305 chip be causing this ?? what else could cause this ??
Old Jan 31, 2003 | 12:00 PM
Morley's Avatar
Misfiring, naa the chip won't do that per sae, but if he is using the stock 305 chip it then it might be running very lean and causing the misfire.
Old Jan 31, 2003 | 12:02 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Here is a random guess
Check the postion of all the spark wires and make sure they are in the correct order.
If they are, check your spark plugs to insure they are good.
If its still misfiring, get a spark tester, like form pep boys $15-20USD and make sure each wire is getting a spark, your distrubutor may be off.
Old Jan 31, 2003 | 05:05 PM
91 z28 350's Avatar
Car: 91 Z28
looked at the motor today and 1 of the spark plug wires was all melted but something else is wrong my car was only firing on 7 cylinders once ( broken spark plug ) and it didn't sound that bad. The guy that did the motor said he set the timing at 3* could that also be doing it ??
O yeah i think it might have the stock 305 chip in it forgot to ask my friend.
Old Jan 31, 2003 | 08:13 PM
Morley's Avatar
Timing should be 6* BTDC.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
