Why do I keep going through coils?
Old Feb 1, 2003 | 06:09 PM
TPI K5's Avatar
Since I have converted my Blazer from carb to TPI this summer, I have gone through 2 brand new coils in mabye 1500 miles (last one probably had less than 500 miles), anyone have any ideas why? This thing is a pain in the *** to replace, and I'd rather not have to do it in the middle of the woods
Old Feb 1, 2003 | 06:27 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
bad spark plug wires can cause that to happen. also a cheap coil, bad ground, and poor mounting (external coil) could also cause this
Old Feb 1, 2003 | 07:05 PM
Kaiser's Avatar
Shorted plug wire(s), bad ground on ign module, no heat sink compound under ign module, resistor or resistor wire in the 12v feed to the coil or ign module.... there are some places to look.
Old Feb 1, 2003 | 07:37 PM
TPI K5's Avatar
Both coils were bought new at the GM dealer. Where does the coil ground? The distributor, ignition module, wires and plugs all have less than 1500 miles on them. I am using the same positive wire for this coil that I had on my vac advance distributor back when it was carbureted
Old Feb 1, 2003 | 08:18 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
What do you have your plugs gapped at?
Kat
Old Feb 1, 2003 | 10:34 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Did the original dist use points?
If so, there is probably a resistor in-line with the power wire.
The resistor was factory installed to help prevent the points from burning up if ign switch was on and the points were just starting to open or close.
Check the voltage on that wire with the eng running and see if it is the same as battery voltage. It should be pretty close.
Old Feb 1, 2003 | 11:24 PM
Kaiser's Avatar
The coil grounds through the back of the ign module, to the distributor body.
Wires being new doesn't mean they haven't burned thru on an exhaust header.
Old Feb 2, 2003 | 12:29 AM
TPI K5's Avatar
The plugs are .40" if I recall, I will check the next time I work on the truck. It had points originally, but I bought it with an HEI distributor, I have no idea if it uses the original wire. I remember checking voltage at the coil the 1st time this happened and it was the same. The wires dont touch the headers either
Old Feb 2, 2003 | 01:28 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The coil ground could be bad.
The metal clip going from the ground plug also goes to one of the bolts that hold the coil down on an HEI cap. If that bolt doesn't have good contact with the metal it can start burning stuff up.
Old Feb 2, 2003 | 12:20 PM
Guest
Guest
Posts: n/a
I would look for the ground strap, thats usually missing, on a coil-in-cap style HEI. It goes from one of the hold down bolts (mentioned in the post above) to the connector on the side of the cap. If this is gone, thats why the coils are burning up.
Old Feb 2, 2003 | 12:44 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The blazer did have a resistor originally. On chevy trucks of that era its a resistor wire. I've changed many of these for people who have put in hei's then had problems. (myself included years ago) Many times it'll run fine for awhile but the resistor wire can't handle the load that hei puts on it, and eventually starts to burn up.
If the wire is still the resistor wire, it will say resistor on it. Also it will have a sort of cloth covering instead of the modern plastic. Dont just look at the coil end though, the resistor wire ran all the way to the plug in on the firewall!! I've seen this wire spliced in the middle before. If you still have this wire just disconnect the firewall plug, remove the wire and replace it with a regular one.
Old Feb 3, 2003 | 12:51 AM
TPI K5's Avatar
It's not a coil-on-cap HEI, the coil is seperate. I dont remember ever seeing a cloth-covered wire anywhere on the truck, but I'll look
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
