Car won't "fast idle"
Old Feb 3, 2003 | 09:32 AM
Brian'sIROC's Avatar
When I start up my car in the mornings it won't "fast idle" anymore. It used to idle around 1500 RPM for a few minutes when cold, now it just idles at the normal idle speed at start up. How do I get my fast idle back?
Old Feb 4, 2003 | 10:48 AM
Is there an idle re-learn feature? Does the IAC need to reset?
Old Feb 4, 2003 | 11:57 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Make sure your coldstart injector is hooked up and working,
the coldstart sending unit is working,
and yes the idle will relearn if you reset the ECM.
Old Feb 4, 2003 | 01:51 PM
Vader's Avatar
Brian,
There is no "teach" procedure on a TPI engine as there is on the V-6 MPFI systems. If the IAC is clean and operating, and the throttle minimum air adjustment is correct, that is all you can do. Did the problems start with the change to the SLP EPROM? Target idle RPM at a given temperature is controlled by the EPROM tables.
If the system was working correctly before with the SLP EPROM, you might want to check the CTS signal. The target idle RPM is heavily influenced by the coolant temperature reading. If everything there is normal, you should check into the IAC operation and TPS voltage.
Old Feb 4, 2003 | 04:08 PM
Thanks for the help Vader and 305sbc!
The prom has been in for a few years now, so I don't suspect that. I will however re-check my minimum air and TPS, since they were messed with when my MAF was acting up. I will also check resistance in the CTS. As far as the Cold start valve goes, it's hooked up and working properly. The car fires right up in the morning, it just doesn't idle like it used to.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
kyle5647
Aug 7, 2015 03:08 PM
