? about afpr
Old Feb 3, 2003 | 11:02 PM
sllt1776's Avatar
Car: 89 Iroc-Z
? about afpr
i'm wondering. to any one that has seen a afpr. do you think it is possible to put a bolt thru the stock fpr cover to make it adjustable? is there some sort of seal around the bolt or is it dry in the part where the bolt is. thanks for the help.
Old Feb 3, 2003 | 11:42 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
check this site out, it explains how to make an afpr out of your stock fpr. should answer most of your questions
homemade afpr
Old Feb 4, 2003 | 12:10 AM
sllt1776's Avatar
Car: 89 Iroc-Z
hey thanks. just what i was looking for.
Old Feb 4, 2003 | 12:23 AM
nikh23's Avatar
sure thing
Old Feb 4, 2003 | 11:18 AM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
I actually did this, and somehow,someway, It bent the piston in the FPR diaphragm so now I need a new one. I'm afraid if I buy a new one it'll do the same thing so I'm just going to buy an AFPR that comes with a diaphragm and everything. It's only like 70 bucks.
Old Feb 4, 2003 | 11:27 AM
Vader's Avatar
You need to be careful with that page from Mike's site - it isn't the latest version.
That page doesn't have the warning about selecting the correct ball size, or the option of using a flat metal disc instead of the ball. There has been a lot of trouble with people selecting the correct ball size for their regulators, and the disc may be the better way to go. It seems that Rochester may have altered the regulator design through the years, and while mine worked well with a steel ball, many have not.
Try this article instead:
TPI AFPR.pdf
You'll need Abobe Acrobat Reader to open the file. (see below)
Old Feb 4, 2003 | 04:35 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Anyone that's swapped to an aftermarket AFPR, please Email me. I want to get a few of these together to make one of my own as well as perhaps check into any changes made between the years.
Does anyone have any knowledge about what for sure will/won't interchange between the years? Or ar they all interchangeable for the TPI cars throughout the years?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
