Low Fuel Pressure
Car: 1986 Trans Am
Low Fuel Pressure
I am having some problems with my 1986 T/A 5.0L TPI. I checked my fuel psi and I am only getting 18-20, now i did check my engine check codes and it was reading a egr valve problem so i replaced that and so no more codes, but i was wondering if anyone had any ideas why my pressure is so low, it starts but only for a couple seconds really, then it just putters down and dies. I replaced the Dist Cap/Rotor Ignition coil, plugs, wires, new Edelbrock 52mm TB, ported plenum, and a new MAF, I was told a while back that it could be the fuel pump itself, but if anyone else has some ideas of somthing possibly causing this, any help would be greatly appreciated
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i concur it happened to me low pressure, then sputters on take off, then intermitten pressure, then **** the bed! new fuel pump and filter and whallah all good
by the way my GTA has 125k on the original when it died.
p.s pump is a real pain in the *** to replace in the drive way,
by the way my GTA has 125k on the original when it died. p.s pump is a real pain in the *** to replace in the drive way,
Car: 1986 Trans Am
Yea i replaced the filter.. and my car is at about 146k... so which is more likely the pump or the regulator ?
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
