boiling/bubbling noise in the tank.
Old Feb 7, 2003 | 11:48 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
my car makes a boiling/bubbling noise after i turn off the engine. i don't know why it does it but it is related to my excessive pressure buildup in the tank. also, my leaking gas from any open orifice of the tank, problem. what do u guys think it can be? fuel pump getting to hot? or something else i'm over looking?
Old Feb 7, 2003 | 01:55 PM
Jza's Avatar
Jza
More than likely, it's not "pressure" and "boiling" that you hear, but "vacuum" and the sound of air being sucked into the tank below the fuel level. This happens sometimes when your vent gets clogged; you're pumping fuel out of the tank creating a vacuum that's gradually relieved through the filler neck or other means.
Check that white plastic valve by the fuel tank. For a test, remove it and see if that helps anything and if it does, find a replacement. You may also want to replace your filler cap. Check the gasket ring around it for cracks.
Old Feb 8, 2003 | 01:04 AM
Abubaca's Avatar
I had the same thing....
....about 2 years ago....
....it just went away, so I can't offer any assistance.
Old Feb 8, 2003 | 02:38 AM
Car: 1988 IROC-Z
i wish mine would go away too :sillylol:
the cap is fine but i'll double check the valve. the valve also makes a loud hiss noise(relieving the presssure?). guessing it's ok??
Old Feb 10, 2003 | 09:21 PM
chitown hussler's Avatar
that bubbling is the gas boiling because there is a vacuum in the tank and any time a liquid is placed under vacuum it will boil at lower temps.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
kx3g
Sep 28, 2015 08:14 AM
Randomtask2
Sep 7, 2015 05:06 PM
