question for ppl with lt1 intake
Old Feb 8, 2003 | 06:06 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
what are the dimensions on that spacer that goes under the distributor? i think it was 1/4" on the thick side and went down at 5° but i'm not sure on the inside/outside diameters. i'd check but my car's two hours away and john's site seems to be down.
Old Feb 9, 2003 | 12:03 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You want the 1/4" in the middle, not the thick side. the thick side should be larger to allow for that but I can't give you an exact figure unless you tell me the outside diameter.
The inside diameter will be 1 3/8" to allow for the distributor to clear with some adjustment (just like factory).
Outside diameter depends on how you fasten the spacer to the intake. I use two 8-32 screws countersunk so the outside diameter must be wide enough to allow for that.
I do sell spacers fully machined for $20 each now.
millicanga@comcast.net
Old Mar 18, 2003 | 08:11 PM
Car: '87 Camaro LT
Engine: 355 L98
john i'm going to use an OD of 1 7/8". on your site it says that the high side is 1/4" thick but in your post you say the middle should be 1/4", could you clarify for me? thanks.
Old Mar 20, 2003 | 07:17 PM
Car: '87 Camaro LT
Engine: 355 L98
bump
Old Mar 23, 2003 | 01:01 PM
Engine: 4.0L
1/4" on the thick side could work, depends on the overall diameter of the shim. If you go to large a diameter with 1/4" on the thick side the angle will make the thin side paper thin.
You want an average so 1/4" in the middle will work fine with ANY diameter shim.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
