SES questions
Old Feb 10, 2003 | 08:36 PM
simple's Avatar
SES questions
i tried pulling codes from it but it wont work. i put the paperclip in terminals A and B then turned the key to acc. instead of getting a code 12, the SES light blinks steady 1...1...1...1...1 etc etc. this happens even without A and B terminals probed.
why arent i getting any codes? is the SES light supposed to flash all the time when the key is on? help me!!! my car is idles like sh** after a few minutes of driving. ive cahnged the IAC and the TPS voltage is fine at all throttle points. after a few minutes of driving the idle will drop to as low as 200 and shoot all the way up to 1200 or so. but once i give it some gas, it drives fine. i need to be able to pull codes to try and find out whats wrong so please help me! =( btw, all vaccuum lines n such are fine.....
Old Feb 10, 2003 | 10:48 PM
Swapmaster's Avatar
Sounds like your computer has gone by the way side. Go to a junk yard and get one for $20 and see if it don't fix the problem.
Old Feb 12, 2003 | 03:34 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Try turning it FORWARD to the 'ON' position instead of the 'ACC'. It might save you some bucks at time.
Later,
Jesse
*edit* I only edited it because I didn't like the way I said it.
eightsixseven
Dec 16, 2024 01:50 PM
Toolsin
Feb 2, 2016 06:55 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
