ODD ODD CTS & Starting Problem HELP!!!???!!!???
Old Feb 13, 2003 | 10:55 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Well for those keeping track, I still havent fixed my intermitten starting problem
Last time I thought I figured it out, I thought it was the Coolant Temp Sensor, cause I had a brand new one ...if the car wouldnt start I'd unplug the old one, plug in the new one (just hanging free for start up, then it would fire rite up, so once it started I'd swap it back onto the real sensor.
Well.... Tonight I took that brand new sensor and actually put it in, and wow, it doenst work either now.
Could it have anything to do with my coolant flow, to much, to little, to cool, to hot (it isnt running hot or cold) Remember I have an LT1 intake with remote T-Stat housing
and Yes, when I switched the two, coolant did flow out of the hole, so I know it flowing someting.
Old Feb 13, 2003 | 11:09 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
First of all, what is your intermittent starting problem? Is it when its cold or hot? Your coolant temperature sensor really doesn't affect starting that much. The only "coolant sensor" that affects starting on earlier TPI systems is the Cold Start Injector switch, which is similar to the coolant temp. sensor in looks and location, but it only controls the CSI and current only goes through it during starting.
Old Feb 14, 2003 | 08:51 AM
Jza's Avatar
Jza
What happens when you plug the old sensor in just hanging free?
Did you have to extend any wires to reach the remote thermostat housing? If yes, did you solder the wires or use butt splices? Is there any tension on the wires, harness, or connector when it's hooked up? The sensor has it's own wired ground, so it shouldn't be a case of the housing not being grounded properly.
What's the temp read on a scantool or DVM on both sensors on and off the car?
Old Feb 14, 2003 | 12:05 PM
86FyrBrd's Avatar
I'll check this stuff today prolly and post again later tonight
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
