Were these injectors replaced??
Old Feb 16, 2003 | 07:09 PM
llvll4l2c91350's Avatar
Well after reading that thread about the 89 and up L98 injectors I went to see if I could tell whether mine were stock or not. They are kinda wide with a very light blue color covering most of the injector and silver at the bottom. They say RP on them with "A260" on one side and a group of other #'s on the other side. Does this mean I have 26lb injectors in there?? If this is the case then obviously they are too much for my car and could be the reason why my idle is erratic sometimes. Thanks for any replies.
Old Feb 17, 2003 | 04:50 PM
Ok lemme try rewording this. To all the people with stock 89-92 350 TPIs (I know there are still some out there),,,can you tell me what # is stamped on your injectors, or if you see anything on it that say "A260"?????????
Old Feb 20, 2003 | 02:01 PM
MdFormula350's Avatar
i cant see the numbers to good but i see something like 6031 or something like that..
Old Feb 20, 2003 | 06:38 PM
91 z28 350's Avatar
Car: 91 Z28
How do u pull the injectors ???
Old Feb 21, 2003 | 12:24 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
That's strange, I just replaced my stock 22# injectors with Accel 24#ers and I see no numbers printed on my stock ones. It says 'RP' on one side and has a 'W' over an 'M' on the other but no numbers. They are silver at the bottom but the rest is a greenish color.
Old Feb 21, 2003 | 12:39 AM
Sounds like the ones I have, except I didn't see a "W" or "M", but maybe they're on the back of it where I can't see. Also there are two groups of number towards the top on the injectors,,,the "A260" and then on the other side, a few others. I'm trying to figure out if these are stock or if someone replaced 'em with bigger ones.
Old Feb 21, 2003 | 01:54 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
OK, I looked closer. On top it has '5249' and '5235437'
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
