cold start injector plug kit?
Old Feb 17, 2003 | 05:25 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Can anyone tell me where I can get the plug kit to eliminate the ninth injector? Any info would be appreciated thanks.
Old Feb 17, 2003 | 06:46 PM
BrandenCali's Avatar
look around
Search ebay or some sites, If you have runners now that dont have a cold start and you just need the one plug, you can cut your cs and solder the end of it, clean it up and install on the rail. The kits are out there.. Good Luck
Old Feb 18, 2003 | 10:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got fuel rail caps if you want one. Shoot me an email at jim85iroc@iroczone.com. $10 including shipping.
Old Feb 18, 2003 | 12:16 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
since search will not find this and i'm sure it's beeen discussed before. anyone have the little plug or know what size freeze plug to use to block the injector hole?
Old Feb 18, 2003 | 02:01 PM
Jim85IROC's Avatar
I'm willing to bet that a thin sheet of steel or aluminum between the runner and the gasket (Not between the base and the gasket) will seal it up sufficiently with a little RTV or gasket sealer.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
