removing a tpi harness
Old Feb 19, 2003 | 07:48 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
Transmission: 350 turbo
could someone give some advice on removing a tpi wiring harness? would other items still be functional on the car,and what all does it effect?thanx in advance
Old Feb 19, 2003 | 08:25 PM
kevinc's Avatar
Car: 1982 Z28
Basically two connections to the chassis: the big black plastic one on the firewall, drivers side, below the relay bracket; and the 2-piece one under the dash, passenger side, near the ECM. There is a lot of variation year by year, and you didn't list the model year so some of this may not exactly match up to your application.
Disconnect the battery, remove the ECM, disconnect the two chassis connectors above, disconnect the starter wiring, and then follow each engine connector. The wiper motor connector is also in the harness.
Right offhand you'll lose the wipers, water temp and oil pressure gauges, fuel pump power, reverse lights, transmission torque converter clutch, and starter solenoid trigger. May be others you'll lose also, again it depends on the year of the car.
Old Feb 20, 2003 | 10:35 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
TPI HARNESS
thanx for the help.it is a 1987 iroc with a 350.it already has an aftermarket 350 turbo tranny in it,so hopefully i'll just have to worry about the wipers and back-up lites.i will replace the guages anyway and the fuel pump.
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
