Wiring harness difficulties?
Old Feb 21, 2003 | 01:26 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
Well, i found a company that sells a 3rd gen harness to 4th gen tps adapter, what kinda connector do i have for IAC on the tb and the harness? does anyone know what weatherpack connector i need for a 3rd gen harness (i assume female) and who sells (male) connectors for a 4th gen IAC?
Old Feb 21, 2003 | 08:18 AM
'86tranzsheezam's Avatar
heres a pic of tpi style tps and its connector...you know, it might be easier to simply ebay the lt1 throttle body and pick up a used tpi style throttle body for about the same price....just a thought
Old Feb 21, 2003 | 08:31 AM
heres iac plus its connector on the harness....
Old Feb 21, 2003 | 05:21 PM
Engine: V8
yea, i dunno about you, but firstly, i already HAVE an lt1 throttle body, i don't think they would have changed the whole thing for the worse, so i'm assuming the lt1 is a better throttle body, and the only ****IN tpi throttle bodies i can find on ebay are missing....you guessed it, the IAC and the TPS, which does me no good whatsoever.
but thanks for the pics, i appreciate it
Old Feb 21, 2003 | 07:50 PM
Well, you're certainly correct. Its no worse. Has 2 48mm holes in it just like mine. Won't give a performance increase and will be a little of a pita to make it work. Just tryin to help you out....no intentions to offend....
Old Feb 23, 2003 | 02:53 AM
Engine: V8
none taken...if i could just find the pn# of the old style IAC motor i think i'd be ok...it looks like it's the same mounts and all and it'd probally be cheaper than anything else
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
