Bolt tightening reccommendations for intake?
Old Feb 21, 2003 | 09:49 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I am getting ready to put my intake back to gether with an Accel Supperram base. Where are you supposed to put the RTV besides along the back wall of the valley? Also what is the recommended bolt tightening pattern and torque. I understand this is very important to avoid warping the intake. Also I have heard you should use thread sealant no the bolts. I bought some "thread sealing compound" at the auto parts store. Is this sufficient? Thanks
Old Feb 21, 2003 | 12:55 PM
kevinc's Avatar
Car: 1982 Z28
You also want to use RTV on the front lifter gallery wall/intake mating surface. Thread sealant on the intake bolts is a good thing, I like Permatex Teflon thread sealant. You don't want the hardening kind of sealant, it will crumble when you remove the bolts later and pollute up the lifter gallery.
The torque and tightening sequence is important...don't have a picture handy and explaining the sequence in text form is time-consuming. It's in all the usual Chilton's and whatnot books, probably on the web if you hit Google.
Old Feb 21, 2003 | 01:21 PM
91Z28-350's Avatar
Yeah, the sequence is a bit tricky to describe, but you basically work inside to outside.
Start with the 4 bolts in the middle, in a zig-zag pattern. Once those are in, do the bolts, I believe, in the back, or could be front. These bolts are a bit different. You do the inner one of one, then the outer. Then go to the opposite side of the rear and do the inner, then the outer. Then go to the front and follow the same sequence.
That's from memory, so I could be wrong. Definitely pick up some type of manual.
Old Feb 21, 2003 | 02:09 PM
Car: '91 Formula
Thanks, I have a Chilton manual, it should be in there somewhere. Im not to sure about the thread sealing compound though. I'll take a look at the manual and see what they recommend
Old Feb 21, 2003 | 02:17 PM
91Z28-350's Avatar
I don't believe they recommend anything for the thread sealing, just RTV and a gasket. Just run to the car store and get the Permatex thread sealer with teflon. Just don't pick up the thread locker stuff.
Old Feb 21, 2003 | 06:07 PM
89transam's Avatar
Like this
6 8
5 7
1 2
4 3
11 9
12 10
FRONT OF ENGINE
THeres the tightening sequence righ tout of my shop manual
Old Feb 26, 2003 | 10:58 PM
1996z28's Avatar
dont go over 30lbs of torque.i usally go with 25.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
