where is my MAP??
Old Feb 25, 2003 | 07:20 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
where is my MAP??
HI
I have 86 5.7 tpi and I have trouble code 34 (MAP) but I can't find my MAP .
please help me to locate it (pic)
thanks in advance
Old Feb 25, 2003 | 09:37 AM
Jza's Avatar
Jza
What PROM are you running? The trouble code lists are somewhat generic and a 34 for one won't be exactly the same as a 34 for another. That and the fact that there isn't a 350 PROM for 86 [for f-bodies], and that anything 85-89 doesn't even have a MAP sensor leads me to believe your problem is elsewhere.
Old Feb 26, 2003 | 11:26 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Jza you were right there is no MAP sensor I was looking at Michell on demand and what I found out is 34 for MAF.
but why did I think it was MAP sensor? because Haynes book said that.
BTW it is Iroc 5.7 tpi
thank you jza
Ivan
db057
Jan 10, 2020 08:55 PM
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
