HSR and E-TEC Heads......
Old Mar 4, 2003 | 05:14 PM
91-Z's Avatar
I am ready to spruce up my 91Z and want opinions on combos. I was thinking about a HSR with E-TEC heads, and LT-4 hot cam kit. I will get the block worked over totally and install .30 over pistons. I was thinking about 500.00 for the HSR, 1000.00 for the heads, 499.00 for the cam kit, 400.00 for the rebuild kit, and 600.00 for the block work. I think that it would be a fairly stout combo.
Does anyone have any experience with this type of combo? Anyone have a desktop dyno and could some numbers. Any input is appreciated.
Paul
Old Mar 4, 2003 | 06:32 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
In a different thread someone was saying the HSR won't cover the raised intake ports on the E-tec/Vortec/Fastburn heads... I'd personally look into the Trickflow 23 degree heads, same price or cheaper...
Old Mar 4, 2003 | 07:23 PM
BOTTLEDZ28's Avatar
Transmission: A4
The E-tec heads are the same thing as the vortec heads. so what ever matches the vortecs will only match up with the E-tecs.
Old Mar 4, 2003 | 08:19 PM
esams's Avatar
Yep, that combo's not gonna happen.
Old Mar 4, 2003 | 08:52 PM
91-Z's Avatar
Well there goes that. Any idea on what heads other than AFR to run on that combo. Don't the Trick Flow's require special push rods?
Paul
Old Mar 4, 2003 | 09:00 PM
JR305's Avatar
I am going to be running some Pro Topline 200cc iron lightning heads with the Holley stealth ram. They seem to be great heads, I will know for sure after spring break.
Here is the website www.protopline.com
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
