Quick question about vette heads
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Would '86 ALuminum Vette heads work on a 91 L98 on my GTA?? or are they different??? Anyone?
The center bolts in the heads would be at a different angle to match up with your intake base. I have 86 vette heads but i am also using a TPI off a 85 camaro. Someone correct me if i am wrong but is it 87 and newer that had the angled center bolt heads. You can either cut a notch in you intake or have the heads modified at your local machine shop to match the bolts holes up to each other. HTH
Jason
Jason
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Forget that man i own a StealthRam....Will it work?? Do they still have the same 58cc chambers and features as the 87+
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
What does the stock Vette run for compression with these heads. Curious as to what my compression will get boosted up to going from a 64cc's to 58cc's. Also what about headers, can i still use and sorta Fbody Headers. as for EGR who needs it the SR doesnt have it anyways, plus i don't need to worry about emmisions in Winnipeg.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do a search on this forum for L98 heads or Corvette heads or something. This topic has been beaten to death.
Car: check
Engine: check
Transmission: check
RBob.
NinjaNife
Aug 23, 2015 11:49 AM
