How to adjust throtle cable??
Old Mar 9, 2003 | 12:56 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
How do I adjust the throtle cable??
Old Mar 9, 2003 | 02:39 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
There shouldn't be any adjustment in the throttle cable. Is yours loose or tight?
Old Mar 9, 2003 | 05:10 PM
white91Z28's Avatar
Engine: TPI 350
when i put the pedal all the way down to the floor the tb is not open all the way.
Old Mar 9, 2003 | 09:39 PM
CEDOE's Avatar
There is really no way to adjust it but I had the same problem and got a new one from GM it was under $20 and instalation was simple . It also made a big improvment in performance for obvious reasons.
Old Mar 9, 2003 | 09:53 PM
patrickm00's Avatar
well, it's basically just a steel cable. you could probably adjust it by moving the crimp on the end by the TPS, though it would be difficult. but if you can cut that crimp off and put on a new one, that should do it
Old Mar 10, 2003 | 12:10 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
You could get a Lokar Throttle cable which is longer and you can then anjust it but its kind of pricey and you have to use the Lokar Bracket, which requireds changing the TV cable as well, again pricey. I did this and it looks great. I did this after installing a LT1 Throttel body and the old cable was too short. But if yours is a little to long, it probably stretched out over time. You could cut off the little metal cylinder on the end and find or make a little screw on end like came with the Lokar TV cable. You might have to make it, you could get a brass solid cyclindrical piece and drill a small hole longways for the cable, then drill and tap for a small set screw sideways and slip it on and tighen. If you cant get it on the cable because the cable starts fraying, put a piece of duct tape on, then slide it past the tape and take the tape off, I had to do that
The stock cable has no adjusting, at least on mind it didn't
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
