Pictures of my work on my TPI runners and base
Old Mar 11, 2003 | 01:59 AM
280Z28's Avatar
http://www.ls1.com/forums/showthread...hreadid=265761
Old Mar 11, 2003 | 02:36 AM
Bort62's Avatar
If I were you, I would spend a little more time and effort Opening up the Passage Vertically between the two Runners in the base.
Remember, the less restriction pulling charge from one runner to the other the better it will work.
Like So :
I actually went back and cut mine even further. Be careful however as I went through in two places, once on the bottom and once on the top. Had to get the bottom one Tig welded while the Top I just JBwelded
Old Mar 11, 2003 | 02:55 AM
280Z28's Avatar
I decided against extremety in the base and am focusing on the runners. I'm hoping the base will just keep airflow smooth. My cam is a strong midrange cam and I expect the shortened but not too short runners to be a good match.
EDIT: I may open it some, but I really don't want to run the risk of going through. I have *no* extra money to be fixing mistakes.
Old Mar 11, 2003 | 08:25 AM
bigals87z28's Avatar
Car: Check The Sig
wish i my dremmel could do that... looks like i gotta find a die grinder
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
tazs2000
Jul 15, 2017 08:44 AM
NBrehm
Aug 25, 2015 11:49 PM
bryan623
Aug 10, 2015 11:33 AM
