Painless Wiring and VATS
Old Mar 11, 2003 | 01:17 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I ordered the MAF TPI extra length harness kit from painless and as i was reading through the manual provided. I noticed it talks about having to disable vats. Is it possible to retain vats w/ the painless kit? or do i have to disable it? I did a search and noticed thats alot of topics pertained to LT1 swaps having to disable vats but not much on regular tpi harness kits. Thanks for any reply's.
Old Mar 11, 2003 | 01:47 PM
Jza's Avatar
Jza
To use VATS you just need to run one wire from the VATS output to the ECM (I want to say pin A10, but look it up and verify to be sure). Your car already has VATS set up in it, right?
Old Mar 11, 2003 | 07:14 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Correct. I just wanted to be sure. Also anyone know how to run the A/C wiring w/ the painless kit? My wires are all hacked and spliced, burnt, and what-not. Which is why i'm asking so i can have it done correctly.
Old Mar 14, 2003 | 10:32 AM
ericoo1's Avatar
Car: 89 silverado,02 s10 blazer
I'll get some answers to these questions in the next day or so for you guys. My mom is the plant manager there, she knows every one of those harnesses backwards and forwards. I'll let cha know
Old Mar 15, 2003 | 01:48 PM
Guest
Guest
Posts: n/a
AC wires and the like (oil pressure, water temp, etc) arent included in the painless harness, its only for the ecm and related sensors. The only AC wire is the one that tells the ECM if the AC is on or not.
Wiring in the VATS shouldnt be hard, like said above, I think its only one pin at the ECM.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
