350 TPI on 305 TBI 92 Camaro
Old Mar 12, 2003 | 03:39 PM
RBelflower's Avatar
Ok,.. It looks like I have found a donor engine. It is a 90 350 with TPI. I have a 305 TBI. After removing the wire harness and TPI unit itself, then replacing the injectors, is there anything that I need to do?
I have noticed that some users say I must replace the 350 chip in the ECM is this correct or just a preference? Will it run to rich?
Rob
Old Mar 12, 2003 | 05:44 PM
Rudy's90irocZ's Avatar
Do a search on swapping from a 305 to a 350. There is alot of info on this swap. I know yours is going to be a little more interesting because you are going from tbi to tpi. I would definitely change everything. I believe there is a place called TPIS on the internet that sells a book on this swap also. Good luck. I hope I helped some.
Rudy
Old Mar 13, 2003 | 01:06 AM
Bort62's Avatar
It isnt that hard...
You want a 305 memcal, perfect oppertunity to start burning your own PROM's.
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
