Error code 43....And what my car is doing..
Old Mar 15, 2003 | 03:00 PM
Bugsy's Avatar
Ok, I am getting error code 43 and whenever the ses light comes on, the car kinda bogs down and loses power a little bit. It comes and goes randomly every time I drive. It usually only lasts about 10-20 seconds at a time. Any ideas of where to start first?
91 Z28 305 TPI 5sp
some of the mods
intake, headers, runners, ported plenum, 3" cat, 1.6rr's, afpr, air foil, msd 6al coil wires cap rotor, hypertech chip, coolant bypass, gutted air boxes, and other stuff that isn't related.
Thanks.
Old Mar 16, 2003 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Error code 43....And what my car is doing..
Originally posted by Bugsy
Ok, I am getting error code 43 and whenever the ses light comes on, the car kinda bogs down and loses power a little bit. It comes and goes randomly every time I drive. It usually only lasts about 10-20 seconds at a time. Any ideas of where to start first? Thanks.
It is your knock sensor/wiring. Lower pass side of block in front of starter is the knock sensor. Check the connector and wire, if all OK then may be a bad sensor. ECM is checking the resistance of the circuit and finding it to be incorrect.
RBob.
Old Mar 16, 2003 | 01:23 PM
Bugsy's Avatar
Thanks for the info!
I know I need to buy the dealership camaro bible but I just can't afford it right now.
Bugsy
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
