New Injectors
Old Mar 18, 2003 | 04:47 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
New Injectors
Hay all I am putting my TPI back together and was wondering if there is a process to putting the injectors back in the fuel rail. I have had them flow matched and cleaned with new O rings. Do I need to lube them or just press them in?
Brian Felts
Old Mar 18, 2003 | 04:50 PM
S10Wildside's Avatar
Don't just press them in, you could damage the O-rings. Silicone spray works nicely. I have even wiped a little Windex on the O-rings to make them slide in.
Old Mar 18, 2003 | 06:29 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Supposta lube the o-rings with clean motor oil.
Old Mar 19, 2003 | 01:56 PM
383 rocket bird's Avatar
Windex actually contains agents which will dry out rubber so I would go with the clean motor oil method. That is what i have used and i works great for me.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
