two stealth ram questions (dont worry, mines already installed)
Old Mar 19, 2003 | 08:12 PM
xanax's Avatar
for one,i have my fuel going into the rail and the regulator is connected to the return line. is this right? i read elsewhere it was supposed to be the other way around, but this seems to be working fine.
the other is where can i find replacement gaskets like the one that came with the stealth ram?
Old Mar 20, 2003 | 01:53 AM
Torque91's Avatar
Fuel should be going into the regulator, easy or hard to change depending on which way u mounted it, and the return line should be connected to the rail.
Old Mar 20, 2003 | 02:20 AM
89transam's Avatar
ive read differently
Old Mar 20, 2003 | 03:15 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Mine is supply line on the regulator and return on the rail.
As for the gaskets, they are 1205 felpro and are available at any auto parts store. The wimpy plenum gaskets are "special order" only from summitracing.com. I have had mine on order for 3 weeks and ordered 3 sets just to save myself the headache next time the gasket fails. As a temporary solution, I used felpro gasket paper from the local auto parts store and cut out a replacement gasket.
Old Mar 20, 2003 | 06:44 AM
Doug Flynn's Avatar
The INLET fuel line goes to the rail and the fuel RETURN line goes on the outlet of the regulator!
There should be instructions in all the rail kits shipping.
Old Mar 20, 2003 | 08:40 AM
Jza's Avatar
Jza
What Doug said. That is how the stock TPI fuel rails are set up as well.
Doug: There's been several posts of people asking how to assemble the fuel rail kit because of a lack of instructions. I know mine didn't come with any (though I feel I didn't need any ). Perhaps you could find out why that is?
Old Mar 20, 2003 | 09:04 AM
Brad's Avatar
Same here, my rails did not have any instructions. However, I figured it out by reading all of the posts on here and looking at some pictures of others' installations. The return line is supposed to be on the regulator, as Doug said.
Old Mar 20, 2003 | 09:52 AM
TwistedIROC's Avatar
Regulator is almost always on the return side......it is easy to regulate return flow than pressure.
Kyle
Old Mar 20, 2003 | 10:32 AM
D F's Avatar
D F
Most of the first rails didn't. Ones shipping now should have instructions due to the apparent need.
Old Mar 20, 2003 | 11:07 AM
JMatlock88's Avatar
Car: 1991 Formula
Yep, mine obviously didnt come with instructions. I guess I'll swap my lines!
Old Mar 20, 2003 | 12:36 PM
xanax's Avatar
yeah i was talkin about the puny plenum gaskets. mine didnt come with any intake gaskets. i had to get fel pros from the local parts store. how much are those special order gaskets?
i figured i had the fuel right. you cant regulate pressure if your inlet is being restricted. you have to keep it flowing a certian rate to get more pressure. you do that by limiting the amount of fuel leaving.
Old Mar 20, 2003 | 01:07 PM
JMatlock88's Avatar
Car: 1991 Formula
Mine seems to work fine the way it is, and it's making nice numbers. Nontheless, a brain fart on my part.
The gasets were on the order of $5 a pair. Like I said, I special ordered 3 sets so I dont have to wait months again the next time I need one.
Old Mar 20, 2003 | 02:15 PM
xanax's Avatar
5 dollars for those thin pieces of paper? gosh. you dont have a part number do you? or do you just call em up and tell em what it is you want?
Old Mar 20, 2003 | 02:19 PM
JMatlock88's Avatar
Car: 1991 Formula
Actually it was a pain in the butt and they had to call Holley Tech. I'll get you those part numbers. Yep, it's sort of a rip off.
Old Mar 20, 2003 | 02:30 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
They're sold under the Weiand brand, since
they first made the tunnelram.
P/N 8984 (WND-8984 on Summit)
HTH
mike
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
